crop rendering
  • crop rendering
    hi all,
    its possible that "cropped" rendering won't work with VFB?
    i've try'd on two machines, the first crashed everytime, the second ignored it totally and renderd the howle image.
    best regards
    Jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    It seems like any of the "region" type rendering modes go screwy when using the VFB - Atleast when using 1.47.03 anyhow.
      u have to set the max frame buffer to the same dimension of the vray fb...
      Nuno de Castro
      www.ene-digital.com
      nuno@ene-digital.com
      00351 917593145
        Well isn't that why the vray frame buffer tab has a checkbox that says, "Get resolution from MAX" ? And I do have that option checked when these distortions occur.
          hmmm...
          have to check...though i now for a fact thet to render region correctly in Vray FB the max should have the same size...no prob using the get resolution from max either...
          Nuno de Castro
          www.ene-digital.com
          00351 917593145
            hi there, sorry for no answer, but try'd it now, and even with same size max crashes everytime.
            Jonas
            www.jonas-balzer.de
            www.shack.de
              I'm having no problem with region or blowup rendering to the VFB... perhaps your image size is just too large for frame buffer rendering?
                hmm 1200x1200....... don't think so.
                Jonas
                www.jonas-balzer.de
                www.shack.de
                  That is very strange. I am doing a region render in the VBF right now. I
                  do this nearly everyday. No problems here.
                  http://mikebracken.cgsociety.org/gallery/
                    even crop?
                    Jonas
                    www.jonas-balzer.de
                    www.shack.de
                      Originally posted by jonnybefree
                      even crop?
                      Are you running this into DR ?
                      nikki Candelero
                      .:: FREE Your MINDs, LIVE Your IDEAS ::.
                        nope
                        Jonas
                        www.jonas-balzer.de
                        www.shack.de
                          jonney, which version of Vray are you using again? Like I mentioned earlier, I'm running 1.47.03 and like clockwork whenever I render in anything other then "view" mode, the VFB doesn't interpret it correctly - even without DR or network rendering at all. I hope this same issue hasn't propogated it's way into 1.5
                            1.49.74. don't know, its fixed in 1.5?
                            Jonas
                            www.jonas-balzer.de
                            www.shack.de
                            • #15
                              This is already corrected for the next RC.
