glass for my car
  • glass for my car
    can't seem to get the glass right. What are good material settings for glass.
    I have to ior set to 1.6. when I look form theback of the car get good reflections off the side windows but the back window does not let me see much and even seems to magnify the cars interior.
    the iamge is below. it may seem cut up because it'r a region render in the vray buffer of tow renderings ooverlayed, but just look at the rear and side glass.
    http://static.flickr.com/94/250155886_f9f578701b_o.jpg
    any suggestions?
    res3d
    Give the glass thickness, just slap a shell modifier and you should be good.
    Eric Boer
    Dev
      yep, one sided glass will do that to ya.
      It treas the whole inside of the car as one big block of glass.
      So do what RErender said and you should be all set.
      p.s. Make sure you have affect shadows ticked in your glass material
        glass for my car
        If I can't put a shell modifer to it, will it not work?
        res3d
          not properly no. Why cant you put a shell mod on it?
            glass for my car
            http://static.flickr.com/79/250330985_3219aaf07f_o.jpg
            I put the shell modifier, glass two sided, affect shadows and walla, it worked. thanks for help.
            res3d
              Anytime
                the other thing i used to do was to simply put IOR at 1.001 for refraction and usually i like putting my reflection IOR at 1.8 or even 2 sometimes. its not physical realistic glass but whatever gets the job done
