LC Flythrough ??
  • LC Flythrough ??
    If i understand this correctly, if not please let me know.
    i am using lightcache in my scene as the secondary GI bounce. In a camera animation i have just 4 cylinders that are moving up and down. Nothing big really. Now if i switch in the Light cache parameters from "single frame" to "fly-through" it will calculate the light cache for the whole animation which i would then save to my linux map server that can be accessed by each render slave. After it computed the LC i switch it to "From File" and this would save me render time right instead of leaving it on "Single Frame"? Just want to be sure if I am right. Dont wanna see bad rendering on Monday. Thats all
    Oh and one more thing. Would you recommend on setting the Subdivs: from 1000 to 4000?
    cheers
    ralf
    Running from saved solutions does not work properly with moving objects as the saved solution only accounts for what is basically a snapshot in time. Your options are to run a rendering frame by frame or to follow the guide listed in the Vray Spot3d help files:
    http://www.spot3d.com/vray/help/150R...rials_anim.htm
    As for your subdivisions, that depends on the complexity/length of your scene. If you're not moving far, a lower subdiv count will suffice. If you're moving a distance you will want more subdivisions.
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
      thx
      cheers mate
