Why is the LC Building so different?
  • Why is the LC Building so different?
    Sometime the Light Cache in my scene only needs 10 minutes to complete. Then a few frames further it needs more then 2 hours to complete the light chache. Is there something wrong ? Its not even a huge change in the camera angle nor is any complex geometry appearing!
    really strange
    thx for any help.
    Ralf
    Can you please send us the scene < nikki@chaosgroup.com > so we can take a closer look. Thanks.
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      thx
      Would it be sufficient if i send you a small part of the file, so u can see the the settings, the animation and materials. The complete file with the hdri might take 100mb.
      How large can an attachment be to your email?
      thx for the help
      ralf
      PS: Btw does the problem might have something to do with an animated visibility spinner?
      I am preparing a file right now!
        If your lightcache scale is set to 'world' this might be the problem.... but I assume your using 'screen' scale .
        Patrick Macdonald
        Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
          Light Cache
          i am using screen
          thx
            Re: thx
            thx for the help
            ralf
            Yes, just send me a piece of the scene.
            Mail attach limit - 8 MB.
            nikki Candelero
              You got Mail
              I send it, just made the limit with 7.3 MB
              cheers
              ralf
                Thanks !
                nikki Candelero
                  @ k-arts
                  Can you point me some frame numbers which one would render normally quick and another - slow.
                  nikki Candelero
                    Rendertimes
                    Frame 139 -- 2:17:59
                    Frame 163 -- 4:56:46
                    Frame 145 -- 00:20:15
                    Frame 119 -- 00:14:50
                    cheers
                    ralf
                    Here is a quick screenshot for further detail
                      I am doing the LC for the "bad" frames you pointed 139 and 163 just as all the rest ( quick enough ).
                      Btw, do you have the speed difference in the LC calculation phase or you are refering to the final render-out time ? As the chart you showed says something else.
                      nikki Candelero
                        LC
                        When rendering the image it seem to me that there is no time difference. The image i am rendering right now (f 159) gives me an estimate of almost 8 hours and is already running 6:30 hours. so it seems to be only the LC buildup to take that long. Just bought 2 new machines just in case, thats why i took me so long to reply
                        thx for the help
                        ralf
                          Checking the f 159 right now !
                          LC - calc - 1:17 min
                          nikki Candelero
                            I had this problem recently, as well...I generated my LC and IM calcs separately, saved the solutions down and used backburner to render my frames. The first sequence completed without issue, but on some rare occasions, I'd have the same problem you're having now. I never could figure this out either, and since I was too much under the gun, never got a chance to post the question, sorry. It was my first vray animation, too, so I wasn't entirely sure it couldn't just be attributed to user error
                            In the end, I just dropped my machine from backburner and rendered the frame independently. I had to recalculate the GI for those frames because the saved solutions just weren't working.
                            Can't wait to see what you find out.
                            ME
                            Talk nerdy to me...
                            Matt English
                            base2studios
                            VizDepot.com moderator
                            • #15
                              Thx for the info
                              I try it your way now, good thinking, havent thought about it yet. I am under so much pressure right now Probably know what i am talking about. if i get a solution i ll post it
                              thx
                              ralf
                              btw Frame 159 afte 6:40 it started the prepass lol
                              20 min later frame was rendered, happieness, frolocking...
