When I have good results using detail enhancement radius 60 with screen scale on let's say a 800 x 600 rendering, does this mean I should change the radius when increasing the resolution?
detail enhancement question
You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.Tags: None
Re: detail enhancement question
Originally posted by GijsWhen I have good results using detail enhancement radius 60 with screen scale on let's say a 800 x 600 rendering, does this mean I should change the radius when increasing the resolution?
nikki Candelero.:: FREE Your MINDs, LIVE Your IDEAS ::.
What exactly does the radius value in Detail enhancement mean? I've read the help manual but its not very explicit:
Radius - this determines the radius for the detail enhancement effect. Smaller radius means that smaller parts around the details in the image are sampled with higher precision - this would be faster but may be less precise. Larger radius means that more of the scene will use the higher precision sampling and may be slower, but more precise. This is similar to a radius parameter for an ambient occlusion pass.
Does a default radius of 60 in screen mode mean that it calculates detailed IR in a 60 pixel radius around each detail? What determines a "detail". How do I know what features in the rendering will be considered details?"Why can't I build a dirigible with my mind?"
Ah fR . . . forget it . . . .
As for de - radius means area, where will be used qmc method. For ex. it found a bricks on the floor - floor sampled with irrmap (a few samples), but when it comes to bricks it starts qmc sampler, which samples 60-pixels around the place, where floor ends and a brick starts (in this case - the normals changed, that's why it thought it must sample this place with QMC). If brick is taller, than 60-pixels, it means that other its parts will be sampled with irrmap (and I think it's sampled at first irrmap pass, as the engine thought it's not an enough detailed area).
Hope, you understand
P.S. To get nice and clear GI-caustics (in case you turned GI-caustics on) - you need higher radius values. Or it will be kinda mix, between loow irrmap caustics and high quality QMC ones, which sometimes makes me maad.I just can't seem to trust myself
CG Artist
Paul-
That is how I understood it too. But if that's correct, then I should change my DE radius from 30 to 150 when I go from 640x480 to 3200x2400. (In your example, the bricks would be taller in pixels.) But above, Nikki says no.
<scratches head>sigpic
J. Scott Smith Visual Designs
https://jscottsmith.com/
http://www.linkedin.com/in/jscottsmith​
http://www.facebook.com/jssvisualdesigns​
In this case you need to change to world. That's it
But I must say - possibly you just don't need to change it, because quality would be the same.... Will check this out.I just can't seem to trust myself
CG Artist
Ok. You definitely need to raise the radius (of course only in screen mode), as low irrmap shadows (really baad, splotchy) would be seen, instead of qmc sampled ones.I just can't seem to trust myself
CG Artist
I did some testing with a simple box floating slightly above a plane, and keeping the radius the same does not seem the right way. Most likely as it looks, is that the radius should be doubled when doubling the resolution. Now that I think of it, it seems quite logical, since it is relative to screen.
So world scale is probably a safer way to go, no worries when scaling up...You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
since de is based on principal of ambient occlusion, the radius should cover the size of the scene, so that any casting objects emit full shadow. However this may produce longer render times.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
