Hi everyone, been reading a lot on this forum and i have nt found any good post on vray sun and physical camera for exterior animation, some for interior but does nt quite apply for exterior, the question is in the title obviously, im having a hard time to callibratre the sun and the cam with the sky and over all image balance, shadows darkness and white balance, somehow it doesnt feel like doing the real thing but more of a post process on the level\brightness contrast on the image. im working with the cinematic camera since its animated and been playing around mostly with the f-number and film iso, working with the 2.2 gamma technique...So what work for you?
VraySun+Vray physicalcam for exterior,what work?
Were not going to tell you how to do your job from scratch, tell us how far youve got yourself and we'll go from there. Show some shots of your scene, give more information on your settings and put a bit of effort in.
Theres been a lot of this recently. Settings vary from scene to scene, you shouldnt be relying on any one set of 'magic settings'.
...:Were not going to tell you how to do your job from scratch...did nt ask for that, i was just asking for general setup for an exterior scene as they are a lot of comparisons for the inside animation.....heres a pic with my settings as you ask, you ll see in the firs frame(first pic the grey house) the lighting is not that bad but when i get further in the animation i have a house that is much lighter in the color scheme but the light is much too bright too much burn....just asking for general lead for sun-physical camera because it doesnt appear to react as the real thing like it is suppopsed to.....looks more of post on the level, brightness\contrast more then anything!
Animation
What kind of rendering farm do you have to have displacement on the grass and all that meshed foliage? It is hard to believe that it is from the same model just a different frame.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
glorybound:It is hard to believe that it is from the same model just a different frame.
What do you mean? The first model the grey house is at the start of my animation, the lighter house is 3 house further up the street in my animation, it was just to show the difference in lighting.
For the render farm question :we have something like 85 computer on the render farm with the vray 1.5 with decent cpu and ram.
Sun/Sky
I see.. I thought it was the back side of the same house. I look foward to seeing a final clip of the animation.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
I havent used cinematic camera at all in my animations. Is it supposed to be used for animations or is it just intended to match cinematic camera parameters?
Anyway, I would adjust lighting levels as much as possible with Vraycam and leave tweakings for postproduction. Dont worry too much about burn areas as they can be fixed in post easily. Render to 32 bit image and adjust intensities to suit your needs in combustion, fusion, shake, nuke, etc...
In real life, u would be adjusting f-stops interactively and hoping to get it right the first time. In post, u can play safely till u get rid of burn zones and get a even lighting scheme. Of course, it will have to be animated through the walkthrough, increasing and decreasing levels and exposure for white levels, black, levels, etc. Not a big deal, really.
Hope it helps!
P.S. 85 computersMy Youtube VFX Channel - http://www.youtube.com/panthon
Sonata in motion - My first VFX short film made with VRAY. http://vimeo.com/1645673
Sunset Day - My upcoming VFX short: http://www.vimeo.com/2578420
Thx for any advice, for the tree i use onyx at start get in max and work the tree from there, create flowers and scatter in the tree with the last set of brach using id, im also optimizing those trees the max i can until its acceptable visually. If anyone else doing exterior animation with 1.5 like to hear your tought about sun and physical camera.
About animating the levels etc in post would be kind of hard to do here since we have a big workflow and project does nt have much time for in post prod, i would personnaly take more time in post but not my choice, got to live with it. I just want to find a good balance with the sun an cam.
Thx, have a good day and a good week!
