How to turn off Vray Log..
  • How to turn off Vray Log..
    Hi Iam trying to turn off the Vray log since it is creating a 3 GB text file which is no use I unticked the Show Window and set the Leve to 1. I also removed the outputpath but however ther is a log file after i deleted it. The problem occurs because of Xfrog plants and the uv coordinates. Anyone have a solution for that ?
    cheers
    ralf
    Just set the file name to be empty in the System rollout.
    However, it would be best to try and clear the errors, as they will still slow down the rendering. In newer builds V-Ray simply sets the invalid texture coordinates to 0.0 without a warning so this is less of a problem.
      Turn off log
      Thats what i did. i emptied the output path but it still creates a log file. Any news when this new build is coming?
      cheers
      ralf
        Try exporting the problem xfrog plant as a 3ds file. Then import the 3ds file back in, re-applying the materials. This will fix the UV coordinate problem.
          yeah what jow said.
          As hiding the log file will not fix your main problem
            Cheers
            I try that , thx for the advice
            ralf
