Wire Frame Mat
  • Wire Frame Mat
    How do you do a fireframe material in 1.5?
    wire frame option is been dissabled or moved somewhere else
    I also tryed to wrap standart material still not working.
    any help would be appreciated.
    cheers
    its done as a map. edgemap or something like that. you can use it in diffuse slot of in opacity slot with a mix map
      Da_elf
      thanks for the quick reply
      I didn't thought about it, I just tryed it and it worked, I think it would be nicer if the option comes back.
      cheers
        there never was the option for wire frame other than edge texture
          seems to work just fine for me. what other method did you used to use?
            some how i always thought there was an option for that like in max.
              No it did work now, i was just looking for the option
              thanks mate
                ah ok cool. well. glad you got it working no matter what the method was. i prefer this as the edge texture allows us to use it in any slot where as a wireframe toggle would only render wireframe
                  The wireframe tick box was only for standard 3dsmax mats. But that doesnt work with vray anyway
                    Quite interesting and a nice feature I need for project of a client. -- Is there any location where I can get that material or does it come along with 1.5? Maybe, I need to develop my own edge-map?
                    --> http://www.tobyatwork.de
                    --> http://www.scriptspot.com/blog/toby
                      Its called VrayEdgesTex and has been around for quite awhile.
                      Just add it to the diffuse slot the same way you would add a bitmap and if you then copy it to the opacity slow it will only show the wires, then you just color them with the diffuse vrayedgestex.
