I am trying to set things up so I can use 1.047 and 1.5 R3 on the same machine. The problem is when install 1.047 in a new directory and change the plugin.ini to point to that directory max still boots into 1.5 ( or at least that is what shows up in the render dialogue).
By changing the plugin.ini what I don't understand is how Vray finds that files that are placed in the 3dmax root directory( 9 files) . Surely these are loaded when you start max ?
Any advice on how you can have both versions installed on your machine - other then copying the entire max directory ?
Thanks as always.
Thanks as always.
