pre-Calc Irradiance
  • pre-Calc Irradiance
    Hello, is it possible to use a irradiance map as it's being calculated? Let say I'm doing a camera fly through calculating every 10th frame for a 3000 frame animation. The machine calculating the irradiance map is at frame 1500 (half way complete). Can I start running the animation on the rest of my farm utilizing the half way complete irradiance map?
    Thanks,
    -Shane
    yes!
    u can divide it in several bits, and then merge all the irradience maps into one!
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
      that could work. but why not set your entire farm to calculate the irradiance map?
        Da_elf.....i thought that only one system could calculate the irr map. Could you please clarify.
        Is it also possible and correct to DR the irr calculation?
        Thanks
        Vivek
          You can use my Imap Control script to render every nth frame imaps in backburner that can be merged together with imapviewer.
          http://varcht.net/index.php?option=c...d=13&Itemid=28
          Eric Boer
          Dev
            why is no one just simply using DR to calculate their irradiance maps? makes no sence to me
              Because those of us with large render farms, have been burned in the past with DR's instability. I flat out won't waste my time calculating my irradiance maps on anything but one machine. If someone can't get a solid irradiance map, in a reasonable amount of time from one machine, they need to learn to adjust settings.
                ah ok.
                  I always calculate my IR on the render farm. Only got 12 nodes but haven't had a problem. Has there really been a big problem with 1.5x and IR DR over a RF?
                  Craig
                    not as far as i m aware...!
                    Nuno de Castro
                    www.ene-digital.com
                    00351 917593145
                      Craig
                      I don't know about 'big', or how widespread, but it is still a persistent problem. I'd use DR daily if it worked, but I've not seen a solution that works here. (Check this thread, and others: http://www.chaosgroup.com/forum/phpB...dbe6de02754d2c)
                      sigpic
                      J. Scott Smith Visual Designs
                      https://jscottsmith.com/
                      http://www.linkedin.com/in/jscottsmith
                      http://www.facebook.com/jssvisualdesigns
                        I haven't personally had much time to really evaluate the new DR, it could be fine for all I know, just in past experience, the more nodes you added to the render, the greater chance of one of them going down, essentially negating the entire render.
                          well,
                          i ve been using DR on a daily base and no problems whatsoever here!
                          Nuno de Castro
                          www.ene-digital.com
                          00351 917593145
                            I'd be content with even that at this point.
                            I'm unable to connect even one.
                            sigpic
