opacity map with sss shader
  • opacity map with sss shader
    hi I tried to make a leaf with the VRAY SSS SHADER and an opacity map
    but I did not reach this effect.
    IS there a way to do that??
    thanks a lot
    try using the 2sided material
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      The sss shader requires that your object has some thickness. If it does not, you'd better use the VRay2SidedMtl material.
        Thanks a lot for your answers Jacksc02 and Vlado !!
