Fog bias -- what does it mean?
  • Fog bias -- what does it mean?
    I don't see in the manual where the Vraymtl setting of Fog Bias is mentioned...
    What does it do? What are reasonable values to use?
    It changes the way that the object thickness interacts with the fog color to produce the final shading. Using this option allows you to make thinner parts of the object more transparent, while keeping thick parts the same, or vice versa. It is not a physically accurate effect and so it's not easy to describe it in real-world terms, but it may be helpful if you are after a specific result.
      How do you control it? How does fog bias 0.0 compare to fog bias 1.0 at the same fog multiplier?
      I'm experimentig with it but i cant get it to work,
      Dusan Bosnjak
      http://www.dusanbosnjak.com/
        1/fog multiplier=the distance, in generic units, at which the object will have the fog color as transparency.
          1 being fog bias (i asked for 1.0 particularly) in your equasion? I did notice that there was a drastic difference when i used -0.99 and -1.0.
          Dusan Bosnjak
            I did a test last year about this paramater. It is one of my favorite spinner, but hard to fine tune.
            Here were the results, feel free to comment : http://www.pixelab.be/blog/2008/09/1...vray-material/
            Could be quick to do the test with RT now
            Philippe Steels
            Pixelab - Blog - Flickr
              @pailhead:
              1/fogbias.
              so 1/-1.0 = perfect 0 whereas 1/-0.99 = 0.01 wich might make a big difference depending on scene and scale i'd say.
              Nice one Philippe! will have to take a closer look later on.
              Regards,
              Thorsten
                cool info. love your blog btw. just downloaded the macpro maxfile and am bringing it into maya to mess around with, using the new vrayfor maya.
                  Originally posted by instinct View Post
                  @pailhead:
                  1/fogbias.
                  Regards,
                  Thorsten
                  Isn't 1/-1.0 = -1.0 ?
                  Dusan Bosnjak
