Max64 and Windows Vista
  • Max64 and Windows Vista
    Probably better if posted in off topic but...I could not use Vray.
    Got my Vistas 64 bits Open licences today..installed easily...photoshop etc.
    But Max9 DOES NOT WORK in Vista
    Browsing Autodesk foruns....
    Any workarrounds?
    I am hopping for a MaxSp1..
    Fernando Blanco
    http://www.blancoimagens.com.br
    i thought there was an equation out there that summed it all up
    MSV + Max9 = no work
    note this equation is valid when MSV = microsoft vista and also when MSV = shit which more or less is all the time.
      Yap. Won't work. Bit confusin'. But I don't like Vista at all. Using server 2k3 x64 - happy
      I just can't seem to trust myself
      So what chance does that leave, for anyone else?
      CG Artist
        Vlado has sucessfully run max9 with Vista RC1, although he had to use OpenGL as Directx was acting odd.
          Well, maybe it was a standalone version
          CG Artist
            Thats.... what can I say.
            Even a Mac can run 3dMax these days.
            Back to WinXP....
            Fernando Blanco
              I've had Max running on Vista with DirectX without too many problems.
              First I had to disable Aero - this caused directX viewport issues.
              Second, I had to run Max as an administrator (if I remember correctly, you right click on the Max shortcut and select run as administrator)
              The above worked for me although I had other issues with Vista so I've since returned to Win XP Pro.
              Rob
              Uniform | Somewhere
                Back to WinXP....
                ?? you mean a mac with running xp?
                Jonas
                www.jonas-balzer.de
                www.shack.de
                  You can buy a Mac that runs with Intel processors, make a dual boot and run 3dmax ( there is also a few benchs in the forum ).
                  And I can not (so far) run Max9 64bits on a new windows OS
                  Fernando Blanco
