Well hello vray people.
We got a bit of a problem here and i hope some of you guys are able to help us.
We are working on an animation, with moving objects and such. so thats to be considered.
Next we want to work in Linear workflow. (we used to not work in LWF)
So a couple of problems occur.
When rendering in LWF, you have to manualy set the diffuse color using the color correct plugin (yes ??? ) and if you check the 'input gamma' and set it to 2.2 the textures should be okey ?
We have made a couple of render test using several color mapping's.
as the client request he wants a 'Sunny' overall look.
We have been using a Direct light as our sun. but using the techniques above our colors look to washed out, or we lack contrast between light and shadow. so the overall look is bleeched. maybe some has some pointers that we can check out.
Next we have tried the vraysun/vraycam. we are wondering how this affects the render times. cause we are rendering around 10minutes of video (PAL 25fps) we have to render allot and time is very important.
So any1 who has worked with vraysun/vraycam in an animation project please describe the pro and cons... ???
Next and last we are gonna do some moving people, that requires a different render workflow (i have read the tutorial with the shpere helpers). does any1 know if that is much more work... ??
Well the best to you all!
Martijn aka PixelStudio
