Using IR Map from Cancelled Render
  • Using IR Map from Cancelled Render
    If I cancel a rendering half way thru its 3rd pass on IR calcs, can I hit save on the IR map rollout and then use that saved map to render with?
    Yes, you can do that.
      Thanks vlado. I did try and use it, and it did seem to work well. That is a huge lifesaver for having to cut a rendering shorter for a deadline!
