noise in image question
  • noise in image question
    I have rendered this image
    http://openrang.server269.com./test-posts/living02.jpg
    Settings used: Secondary bounce - QMC, Min rate- negative 6, max rate-0, HSph subdiv- 50, Interp samples 30. Rest default
    There is noise on the wall and ceiling . esp noticable around shadow cast by TV. Any advice on which setting to change to eliminate this? Any other C&C about the image also welcome
    Thanks for any help
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    If the noise is coming from an area light at the window, you can try to decrease the QMC sampler Noise threshold a bit (maybe 0.005) and/or increase the subdivs for the light.
      thank you for the reply.
      I have a Vray light at the window. Is this considered an area light?
      would that be the rQMC sampler?
      mark f.
        the rQMC Sampler is found in the render settings (it's a seperate rollout).
        And yes, a vray light is always an area light.
        Regards,
        Thorsten
          thanks for the clarification. I am new to Vray and have lot's to learn
          I like it so far.
          mark f.
