I am trying to use a hi-res hdri, but it is really blurry. What am I doing wrong? I am using a Dosch HDRI, is the HDRI the problem?
Blurry HDRI
Blurry HDRI
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Tags: None
HDRI
It is a 2048 x 1024 Spherical MapBobby Parker
phone: 2188206812
- ​Windows 11 Pro
Well, if you think about it, for a camera with 90 degrees horizontal FOV, when the 2048 pixels are stretched around the scene, only 1/4 of them (512) pixels will be visible to the camera. So if you are rendering at more than 512 x resolution, it will look blurry. A solution would be to use a higher resolution HDRI or a "screen" background.
VladoI only act like I know everything, Rogers.
Back to my thread in this post again as vlado is mentioning, only a portion of your map is visible to camera so you'd be better of using a planar map as a backgroud either as a comped bg or as an environment map with a gi and reflect refract override.
it occurred to me that it might be useful to have a horizontal tiling option (integer values only) for hdri - I know that would be way wrong but since its a tiling texture it might be useful for an interior hdri that does not have an obvious main light - correct me if its a stupid idea!
yeah but isnt the "spherical" just a mapping - it must have an edge somewhere and the top of the sphere would have the same polar distortions
I know tiling it would squash the reflections etc but as an illumination source it would double the resolution - sorry glorybound, in danger of hijacking the thread here
I wouldn't necessarily consider 2048 px wide for an equirectangular panorama to be high res.
The highest res commericially available HDRI's I'm aware of are here:
http://www.sachform.de/webshop/produ...c8ededa6b7f4bd
They are 8000 px and sometimes they are not high enough res to be used for backgrounds (depending on the size of the image I am rendering)."Why can't I build a dirigible with my mind?"
Actually check these out...10,000 x 5000 pixels!
http://www.hyperfocaldesign.com/hype...dri-skies.html
They're pretty killer...Needs more cowbell
we stitch our own at 30k+ :P we bought some hyperfocal ones, and am not really satisfied with the dynamic range they give to be honest. Plus they are Big, but not really sharp...could as well be 8k upscaledAnd given that there's no bundles and each "High Res" HDR is 60 bucks i was rather disappointed.
Regards,
Thorsten
Originally posted by instinct View Postwe stitch our own at 30k+ :P we bought some hyperfocal ones, and am not really satisfied with the dynamic range they give to be honest. Plus they are Big, but not really sharp...could as well be 8k upscaledAnd given that there's no bundles and each "High Res" HDR is 60 bucks i was rather disappointed.
Regards,
ThorstenPatrick Macdonald
Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
