...anyone have info on the Vray AA filters? ....are they sharpening or softening filters? ...do they render faster than standard AA filters? ...etc.
VrayLanczosFilter and VraySincFilter
The sinc filter is a sharpening filter, while the lanczos one is a smoothing filter. They are neither particularly faster nor slower than the standard filters, but may look somewhat better (although this is very subjective).
VladoI only act like I know everything, Rogers.
Which filter to use depends a lot on what kind of picture you're rendering. for instance doing something like architectural viz you'd usually want to use a sharp filter and sometimes even edge enhanced (though I don't recommend that) however if you were to go for a natural look then a smoother one is better. Also if you are doing animation you will get much more flickering when using a sharp filter. I usually use the VRaySincFilter but it's just a taste thing
Sharpening filters also have a nasty habit of causing serious edge artifact when you have bright areas like a high reflections of a light source or sun next to a darker area. This was not an issue before real world lighting. However, because in Vray everything is rendered in float (with 0 being black and 1 being white) the bright area could be a value of 5 and the dark 0.02. The sharpening filter will get you an "error" at that edge actually giving
you negative values basically looking like a nasty black edge.
This can actually be avoided by using a smoothing filter and, if sharpeing is needed... do it in post.
