Hey....I have some Benjamin Moore Colors that I have swatched from the website. So make a vraymat and use VrayColor and input the rgb values...Of course the colors are too bright. So is this the right way to do it? Then just adjust the rgb multi to like .75 or whatever? Should I use different color mapping to adjust it? Thanx all
Vray Color and Paint Colors
For now, your only solution to a colorcorrect type of plugin for Max 9 64 bit would be:
http://www.af-video.com/index.html?ahls_fl
color
I use Benjamin Moore also, I drop a vraycolor in the diffused slot and set the RGB multiplier to .255. Works like a charm. Read the sticky post on this method.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
Sweet.... I have always told me friends that I need a new plugin with a spinner...But ....well.....Perhaps that's the reason I dont get any calls......Stange..
Juju: Sweet.....Checking it now
Bobby: NIce just tried it and bam.....right on target....or is it Targeee'
Daforce: Can you send me the special documents and settings that Nikki was talking bout....Damn keyboards.....
Perhaps a little Crackdown tonight....
hehe, there was also a method that Vlado posted about. Its for getting spot on colors.. involves abit of math and 2 renders but will do the job
http://www.chaosgroup.com/forum/phpB...ic.php?t=18421
There thats the sucker.
Yeah crackdown would be good.. havnt played xbox in awhile actually.
Only problem is finding a time when we are both up..
What was your nick on XBL again.. solid firebat?
i recommend this site for paints, it has all of the major manufacturers.
http://www.colorcharts.org/ccorg/
...and then the CoolPicker plug in allows you to sample color from anywhere on your screen. i open the paint swatch in the background, sample the color directly off the website, and then apply the gamma correction.
RGB
I use linear, but I have seen some pretty great images using other. I do most of my color tweaks in PS so it doesn't really matter I guess in my case.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
Originally posted by crazy homeless guyi recommend this site for paints, it has all of the major manufacturers.
...and then the CoolPicker plug in allows you to sample color from anywhere on your screen. i open the paint swatch in the background, sample the color directly off the website, and then apply the gamma correction.Ben Steinert
pb2ae.com
When RC4 is release the Vraycolor map wil have a gamma spinner. Which will be exactly what you need.
