Rendering - Transforming Vertices ?
  • Rendering - Transforming Vertices ?
    Hello friends !
    I work with Linked Geoemtry files from Revit in 3dsmax.
    For some reasons, vray needs a very long time for preparing the rendering.
    In the current task I always can read the message: Transofrming vertices..
    Well the linked geometry is very massiv, and so I wanted to ask, if there is any way to reduce this transforming, or to bring it away for the calaculation with vray.
    thank you for every little help,
    Bernhard
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    I have found a lot of imported geoemtry from revit has too many verts and needs welding. I don't know if this is the software, or just the way people are building these models.
    www.studio2a.co
      if I remember correctly this is a known issue with rc3, but I seem to remember vlado saying it's fixed in newer builds.
      edit:
      here's a thread about it:
      http://www.chaosgroup.com/forum/phpB...light=vertices
        hmmm
        Well, I couldn't read that this problem was fixed until yet. But vlado wrote, that it will be ixed soon, or did I missunderstand ?
        bernhard
          He said it was fixed in the newer builds. Which havnt been released yet.
          But shouldnt be too much longer I would think
            Bummer, I just upgraded to Viz 2008 and am getting the Transforming Vertices problem .... it stays there seemingly stuck for a while with cpu usage at a minimum, but most of the time I get an application error and Viz closes.
