Seperating trees into separate pass (shadows? Reflections?)
  • Seperating trees into separate pass (shadows? Reflections?)
    I have a very large, high poly, scene which contains a bunch of instanced proxy trees all over the place. The issue is that with the proxies turned on the scene crashes every computer on our farm. I am running out high resolution stills at around 4500 pixels (X). With the proxies off I can render the scene with no problems.
    How can I separate the trees such that I can render the scene and have them reflect in the glass etc...but not show up anywhere else. Then How do I run out a separate pass of just the trees so I can comp them back in and still have their appropriate shadows being cast??? Is this too much to ask Vray to do?
    Thanks everyone...
    Brian M. Parker
    Cooper Carry Inc.
    www.coopercarry.com
    First, have you tried rendering to a vrimg? make sure to disable the Max vfb.
    If that still won't render
    Create matte objects out of the window walls, leaving the reflective glass material intact but with a -1 alpha. Then when comping the tree layer duplicate it and invert the alpha, giving you a layer with just the reflections to add to the base.
    Eric Boer
    Dev
