Roof tiles - geometry or displacement ?
  • #16
    i did an animation with a saved irradiance map of that building (plus 3 other buildings, and it took 3-4 minutes a frame to render. the irradiance map took about 6 hours to render though, although it was alot of frames
    • #17
      Hello Da_elf,
      Very good time! what kind of tiles (proxy?), what resolution, did you do irradiance map calculation on every frame? If you don't mind me asking
      Regards
      Srdjan
      • #18
        Hello DaForce,
        I miissed your post
        The way I did is, I made a spline and extruded by 0 thickness, maybe wrong? so no plane involved.
        My idea was to do UVW tiling in the model rather to map, because you need different amount of tiling in different segments.
        I got 1 map and 1 complimentary displacement for tile, but if you don't mind you can help me with another one
        Regards
        Srdjan
        • #19
          Yeah extrude spline should be ok.. all depends on polys so if they are nice and even its ok.
          It seems the maps I have only have bump maps which would not be good for displacement well not without some serious PS work.
          I can give them to your if your still interested.
          • #20
            Thanks DaForce, I guess this what I got will be good enough. Let me share my source for this, in case you, or other guys need it
            Sirkus shared his stuff, thanks to Sirkus.
            http://www.cgarchitect.com/vb/14582-...rior-shot.html
            Regards
            Srdjan
            • #21
              Yeah as a proper displacement map thats not very good either. If you displace it on a simple plane with no diffuse map you will see it displaces wrongly, mainly because of the shadows.
              However it seems to look ok in the render, but i think it would look bad up close without some PS work to remove teh shadows from the disp map.
              • #22
                Yeah, you are right, I think it should be more gradually. I used to have somwhere much better displacement map, and tile itself, but can't remember where I saved...
                Regards
                Srdjan
                • #23
                  In swedish (and pictures!), but this is how I did it, simple with a texture and with DisplacementMod.
                  http://www.animate.se/viewtopic.php?...ight=takpannor
                  • #24
                    one of daforce's posts was my post. my tiles were displacement and the procedural maps used to make them are in that link
                    • #25
                      Hello Svante!
                      Hello Da_elf!
                      thank you very much for your replys, your posts are very usefull
                      I will try and see which is going to work best for speed, looks etc.
                      Regards
                      Srdjan
