Fast glass material
  • Fast glass material
    Hi guys,
    I am in the final stages of putting a visual together and I am populating a servery with glassware. I am having a really hard time creating a realistic but fast to render material.
    I was hoping somebody could offer some advice.
    Thanks,
    Marcus.
    Maximum refraction, falloff in reflection, affect shadows turned on. Make sure its got a thickness of between 5 and 10mm and a good environment, and youre good to go.
    I'd put a slight bluey/green tint to the fog too, but depending on the thickness of your glass or scene scale you'll need to mess about with some numbers.
      Mine is always :
      Anyway, I'm not sure that the "avoid 255" rule does apply for this type of material...
      Philippe Steels
      Pixelab - Blog - Flickr
        If it's totally clear glass then turn it off to gi too.
          very clever, never tought about it
          but... turning emit GI off or receive GI off ? or both ?
          Philippe Steels
            Both, make it completley invisible to it.
              It's strange, I've just made a quick test and wrapping the glass mat has the same effect has unchecking "affect shadows"
              When changing GI attributes in the object's Vray properties, it works ...
              Philippe Steels
