Arial
  • Arial
    I have had a couple requests for Arial.... any suggestions before I start one of them? Should I use SUN/SKY/CAM or a skydome? Would you recommend HDR or not? How would you recommend I handle the whole not having a horizon?
    Any help would be greatly appreciated.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi Bobby,
    For Aerial shots the Physical Sun has always served me well. As for horizons, maybe this could help out: www.landdata3d.com
      Birds Eye
      I'll check that link out, but I meant birdseye. I am looking down at abut a 45 degree angle.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        pond water
        I have a pond on my aerial, but all the water materials I can find are nice pool water. Does anybody have any ideas? Also, I have a hundred proxy trees, but somehow by tree trunk is green so somehow that maps got mixed up... anyway to fix this?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Proxies need to have a multisub applied to them. So as long as your trunk is 1 material ID and your leaves another it shouldnt be a problem. Sounds like you may have the whole tree the same ID or you havnt applied a multi sub material to it.
          As for teh water, try maybe some dark green fog to get that murky look. Dont forget alot of what make a pond a pond is the pond floor, its often rather dirty and dark.
            proxy
            the tree is actually 2 parts and when I create the proxy I turn it into 1. It has always worked before, I think.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Still needs a multi sub.
              Possibly you have both parts of the mesh as the 1 material ID.
                proxy
                If I do am I stuck?
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Yep. You will need to remake your proxies with proper material ID's
