reducing noise in interior scenes
  • reducing noise in interior scenes
    Guys
    I have quite grainy internal base images at the mo. In my rQMC the noise threshold is at 0.01 Is this the best parameter to play about with to reduce the 'noise' throughout the image. I have some blotchy areas also......any ideas...My render time for the base scene at the mo is about 4 mins and dont really want to go higher than 7 mins per frame if I can help it?
    Cheers
    Sparky
    a ss of your rendersettings and even an image of what your noise and splotches are would be helpful.
      no probs, here's the image, you'll notice the areas of noise.
      [/img]
        looks like noisy area lights would be my guess. try raising their subdivisions. Also if your using a fairly high quality irradiance map, try storing the lights with the irradiance map, that will definitely get rid of noise, but you might start to see some splotches depending on other settings. I'd recommend some searching of the forum, as this is a common issue.
          Try raising your Global subdivs multiplier to about 8
          "Why can't I build a dirigible with my mind?"
            How do you store the lights with the irradiance map? and would this dramatically increase the render time?
              on the 'quasi monte carlo GI' panel??? or elsewhere?
                tick "store with irradiance map" in the vraylight rollout
                Nuno de Castro
                www.ene-digital.com
                nuno@ene-digital.com
                00351 917593145
                  on what part of the rollout??
                    Got it.....will this dramaticallly increase the render time?
                      The global subdivs multiplier is in the rQMC Sampler rollout. Try setting it to about 4, re-render and see if it helps the noise. If so, try turning it to 8 and see if it eliminates all noise.
                        Nuno de Castro
                        www.ene-digital.com
                        00351 917593145
                          cheers....
                            Nuno de Castro
                            www.ene-digital.com
                            00351 917593145
                              Yeh, I have this at 10
