I've set up an architectural scene using the vray physical camera with the vray sun+sky system. I'm also following a LWF (.255 method). Everything is working great. Woo hoo! I'm done!.. Not so fast. I was just informed that I will need to produce one exterior elevation view.
If I were using standard cameras I could just tick the orthographic checkbox, but the physical camera doesn't appear to have that option. So unless there is another option I guess I'll have to use the physical camera and adjust it to a 1000mm lens or higher to get a fairly low perspective elevation. Is there another method I should be aware of?
