Hi, I have a animated (camera and objects) scene with a steelwire that needs to be re-rendered because of a displacement error that made the wire to thick. This means that I need to render the steelwire plus a area on the sides of the wire because the existing wire is to thick (the red areas on the picture bellow) Is it possible to render only the red areas in the re-render?
Tested the VRaySphereFade, but that only use a sphere and to cover the wire from top to bottom it's really not far from rendering the entire scene instead of only the steelwire areas. It would be nice to use the wire object to define the fade areas instead of a sphere. Any ideas?
Thanks from Chris
Thanks from Chris
