Workflow : Render elements, vrimg to exr
  • Workflow : Render elements, vrimg to exr
    I am behind the curve on this one but I normally render the straight RGB without bothering with Render Elements. Now I am getting into them and have just gotten a copy of Nuke to play around with and now I'm all about me render elements. So the questions are as follows:
    1. If you choose to render to the vrimg file format with what application can you check you're rendered output ?
    2. If you choose to save an vrimg output from the V-Ray: Frame Buffer rollout do you also save the file in the Common rollout ?
    3. Are the Render Elements automatically saved when you choose the vrimg format ? or do you need to active this function ?
    4. If you choose to render to open exr are render elements automatically saved with the file ? Do you normally convert your files straight to open exr ?
    Thanks as always for your help.
