PROJECT... R3 "transforming vertices problem". NEE
  • PROJECT... R3 "transforming vertices problem". NEE
    Currently unable to move forward with the project as vray just won't render the file. Send an email out to chaosgroup but I'm hoping someone can read this and send me the newer builds which apparently has this fixed. Please help!
    Image comes out in like 1 second in scanline but won't get past "Transforming Vertices".
    can you describe your scene?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      its a revit model that we were supplied with... comes in as thousands of objects. Every piece of geometry is its single object.. Can't collapse because it takes forever and when you try to render with vray, it goes into "transforming vertices" and stalls. Its a bug. I did a search and found a topic on it.
      Its a 50+ storey tower.
        Hm. Have you tried to export some of 'em/all to VRay proxies ? We used newer builds before the "BIG coming" ( )final( ) and this problem was no longer ours. But, I found it's sometimes usable ...
        I just can't seem to trust myself
        So what chance does that leave, for anyone else?
        CG Artist
          hey
          well this happens to me when i have autocad and revit files however it deals with the way you import models it will always tranform them in the begginning like that. im assuming this is a large file becuase it takes so long. however there is no way to avoidj it and i doubt there is a bug. my autocad and archicad scenes have always done this.
          Hope it helps. try minimizing the polygons on some things or creating proxies etc.
          Ruben Gil
          www.spvisionz.com
          www.linkedin.com/in/s2vgroup
            Re: hey
            um, its a R3 bug, Once we upgraded to Vray final, the problem went away.
              i have the same problem . "Transforming vertices" takes forever. with max8 it is fine... max9 64bit ....zzzzzzzzzzzzzzzzzzzzzz
              MBA Studios | 3D Images & Visual Effects
                this is a well documented old bug
                  .. but that doesnt help me, because there is no RC4 or RC5 for us
                    So im also assuming you dont have your dongles and therefore cant use 1.5 FINAL ?
