Anyone know the files / changes needed to copy a working install of VRay 1.5 in 3ds Max 9 to a new install of 2008 no the same machine?
I really would like to move to 2008 but not at the risk of breaking 9... I thought I'd just use the 1.5 installer and tell it to use the 2008 folder but it wants me to uninstall it from max 9 first - and there's no way I'm going to do that. The only solution I can think of is to manually move the plugins folder / ini files but I'm getting errors.
Here are the files I can think of that would need to be moved:
3ds Max 9\vray* (4 files)
3ds Max 9\plugins\vr* (2 files)
3ds Max 9\plugins\vrayplugins\ (16 files)
3ds Max 9\plugcfg\vr* (4 files)
In addition, the VRay entries in plugin.ini would need to be moved / paths changed (from Max 9 path to 2008 path)
Any suggestions? I did the above and got a ton of errors on startup of 2008...
