Stuck with this golf course animation... only problems on the way to the perfect animation...
proxies solved, trees are distributed, memory is no longer an issue... however last few days i've spent managing AA for my trees in scene - those far away from camera.
I've tried each and every suggestion from the forum... some did the trick pretty well but the thruth is (as i concluded) if you want to achieve complete flicker-free result in animation like this one, you have to have render farm since 25 min per frame is not acceptable...
Anyhow, i'm posting two images from the movie, from 2 following frames... if you look at them you will see that trees in front are quit still, but those in back are the problem.
www.focusgrupa.com/1.jpg
www.focusgrupa.com/2.jpg
My current settings are:
Adaptive DMC 1,5
Video filter
IR/LC saved prepasses
Vray 1.5 SP1
Max 2008
Frame time now is cca. 5 minutes on DR with two PCs with configuration (that is not really state-of-the-art):
AMD X2 64 3800+
3 gb ram
XP SP3
so if you can think of any trick how i could increase AA quality but not send rendering time sky high.... i would appreciate it.
thank you
sinisa
Adaptive DMC 1,5
Video filter
Vray 1.5 SP1
Max 2008
AMD X2 64 3800+
3 gb ram
XP SP3
thank you
sinisa
