Framestamp - Imagename
  • Framestamp - Imagename
    I was wondering if it's possible to add in the framestamp, the name of the image that you're saving.
    So if you're saving your rendered image as 2008-01-10 library, could that be added to the framestamp? Since we're using a different way of naming our files, adding the filename of the Max scene would be useless to us.
    If this is possible, it'd help us alot.
    www.artbyarjan.com - Online portfolio (temporarily offline)
    @home:
    / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
    / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
    @work:
    / Intel Core2Quad Q9450 @ 2.66Ghz /
    Nvidia Quadro FX 3700 / 8Gb Ram /
    / Vista Bussines x64 /
    Currently this is not possible, but I'll add it to the wish list.
      Thanks vlado!
      While I was thinking about how I could solve this at the moment without needing to type it out with EVERY single render I make, I thought about if it would be possible to have the framestamp load information from a text file or something. Kind of like the max script string.
      For example, we're thinking about using the following format:
      < yyyy-mm.#### name > so: < 2008-01.0001 library > (without the < >)
      Now, say we'd make a simple .txt file with on every new line a file name, like this:
      < linenr. "filename" >
      01. 2008-01.0001 library
      02. 2008-01.0002 library
      In the framestamp info, you'd enter a string like this %txt<filename&location?>-<linenr.> and vray would read the file, look for the specified linenumber and then add the name behind that linenumber as framestamp?
      %txt<renderseries&c:\documents...>-<01.>
      It sounds complicated, and maybe it's not an easy way at all and would using the name of the image be alot easier. But it could be worth considering?
      -edit-
      After thinking and discussing about it, I think this is a too complicated option...
      @home:
      @work:
