Is there a way to render material ID's in vray? I looked into PSD Manager, but it doesn't work under 64. Currently I put a gray material on everything except the element I want to isolate, which I make red, and I render that out. In photo shop I can mask the red. This works, but there must be a better way.
Material ID
Material ID
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
You can use either the VRayMtlID or MultiMatteElement render element depending on your needs to generate a selection mask for the proper ID or you can just use the vrayMtlSelect to isolate just the material you need on black.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Material ID
Did I mention that I use PS for post? Do I need something that supports rpf's like Combustion?Bobby Parker
phone: 2188206812
- Windows 11 Pro
You don't have to save out to anything special unless your batch rendering an animation which I doubt your doing since you say it's photoshop. Just switch to the correct element at the top of the VRAY FB and save it like normal.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
material ID
I can show Object ID in the VFB, but it shows them all. Ho do I isolate them? I must be missing something.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Then probably what will work best for you is the multimatte render element; just change the Object ID for the nodes that you are interested in (from their Node properties); then in the multimatte element, enter that Object ID e.g. for the Red channel. This should be all to get a mask for the desired objects.
VladoI only act like I know everything, Rogers.
Material ID's
Perfect! What does the MatID Do? Do I only have RGB?Bobby Parker
phone: 2188206812
- Windows 11 Pro
PSD manager
I'll look closer at PSD manager. I just saw on there homepage a disclaimer that they don't support 64 bit. Material ID seems to be doing the trick for me. It produces one image with different colors for each material. It'll safe me some time preparing for PS post.Bobby Parker
phone: 2188206812
- Windows 11 Pro
From their website:
System Requirements of psd-manager 2.0
Autodesk 3ds max 6/7/8/9/2008 (32-bit and 64-bit) or VIZ 2005/2006/2007
http://cebas.com/products/feature.ph...PID=38&FID=326
Material ID
I guess I was confused by this statement:
Note: While a tryout version of psd-manager 2.0 for 3ds max 9 (64-bit) is not available it is fully supported by the full version.Bobby Parker
phone: 2188206812
- Windows 11 Pro
