bath render to vrimg format
  • bath render to vrimg format
    is there a way to batch render vrimg files? ...or do they need to be rendered one at a time? it would be nice if i can just hit render and walk away since i have a group of 20 elevations that need to be rendered to vrimg format.
    How are you going to set up the batch rendering? If it is organized as frames of an animation, then it is not a problem.
      In any case, there's a "batch render" option under the render menu...
      That works, particularly in conjunction with scene states and render panel presets (to which you can save the output image path, amongst other things, and then assign a preset to a render job).
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        right now they are organized as individual cameras, and i was looking to do a more traditional batch render.
        ...but i still don't understand how organizing it as my cameras for frames of an animation will help. if i render an animation of 20 frames, does vray ____ the vrimg file, even though the vrimg file is under the vray frame buffer dialog, and not max common parameters?
        if this is documented in the manual, i will be happy to read about it there, but i didn't see it.
          ...but does this work while rendering to vrimg? ...or can i render to exr, and still acess the vray render elements such as vrayrawlighting, vrayrawdiffuse for compositing back together.
          i know i can write a exr with this information directly from the vray frame buffer rollout, but is this information stored in the exr even if the exr is written out of the batch render dialog?
          ...i haven't purchased ProEXR yet, but that would certainly give me a reason to.
            It sure should do.
            As saving a preset for the render dialog saves potentially every path, map and semi-obscure setting in the render panel rollout(S), you will be able to save as many presets as the shots, and then in the batch render assign to each shot its camera and its aptly named preset.
            Lele
            Disclaimer:
              ok, i think i got it. thanks for the excellent tip.
              i will try it later today. our network is being upgraded, including our machine with the vray license server.
                It sure should do.
                i am really struggling to figure out the render dialog presets. mainly, how do i save them? ...i know where the vray presets are, but the batch render does not read those, it is looking for the saved presets at the max level, which i can't find.
                ...banging my head against a wall.
                ....am i just an idiot?
                  nevermind, i found that also. it only took me an hour. i was an idiot.
                    lmao man!
                    Ever heard of the expression "hidden in plain sight"?
                    It actually does work often enough XD
                    Lele
                    Disclaimer:
                      Strangely enough I still think of baths when I read this thread
                        i just noticed the typo. whoops. funny though.
