path sampler option
  • path sampler option
    For some reason the path sampling option under DMC is now greyed out. Has anyone else had this?
    From the SP1 changelog:
    "Schlick sampling is now the only path sampler supported by V-Ray"
    I believe this is because Schlick smpling is the most efficient from the old set of three, and to force everyone to use it. No access to the legacy sampler can only be a problem if you seriously need to match he noise pattern of a previous render pixel by pixel, but imo thats a rare issue.
    A.
    credit for avatar goes here
      Well, it's not only a case of noise matching.
      It took me years to get to understand, and use PREDICTABLY, the old options.
      It's taking me more time to get used to the new sampler.
      So oftentimes i have to perform renders, test and check, before submitting the final image knowing it will behave as i want it to.
      Also, the previous samplers rendered LC and PPT in a more random way, leading to a better interpolation of samples by the eye when samples were very few (ie. i would be immediately able to "read" the image as the calculations started.).
      Me, I'd like to see the previous options back and available, while the new one could stay as a default.
      Maybe i'm the only one...
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        Yup, all true. I'm on re-learning some thumb rules too.
        (If you can read morse, funny things can be read from a schlick LC prepass. hehe )
        A.
          Ahah, that one made me laugh heartily
          Lele
          Disclaimer:
            Ah ok....thanks for clearing that up. I haven't used vray in a while so iguess the last time was pre sp1
              Just a quick one - i guess that you can still change the path sampler...
              renderers.current.dmc_pathSampler_type = 0 (0,1,2)
              Michael
              This signature is only a temporary solution
                it changes the greyed out menu, but not the sampler (check the LC for reference)
                Lele
                Disclaimer:
                  that's in fact what i doubted after running some tests just now
                  well, a pity... we have to live a life in Schlick then, could be worse.
                  Best regards, Michael
                    My vote for the old sampling to come back on ... wat's the issue of the old sampling.
                    No harm giving the user some options in that?
                    best regards,
                    Studio Max 2009 x64
                    X5000 Chipset | Dual Core Intel 5140 | 4G RAM | Nvidia FX3450 drv 6.14.10.9185
                      Bump!
                      Any ideas/news/infos on this, Vlado?
                      Lele
                      Disclaimer:
                        The old sampling cannot be added back. However, for the SP2, there are some improvements in this area.
                          Thanks, twice for today, for clearing things up
                          Lele
                          Disclaimer:
