Brute Force as Primary
  • Brute Force as Primary
    I have a question regarding the Brute Force being used for primary bounces.
    I have usually used IR map as primary so was used to being able to reduce the IR map as the image size grew. Is there a similar way to cut time down
    to increase image size for the Brute force approach?
    ( oh yeah, I'm using Brute force/Light Cache)
    I have the scene set up now so it looks good at about 900x___ pixels, but it takes around 30 minutes! So, should I forget about this if this rendering has to be 3000 x 2400 pixels? Any suggestions are really appreciated, just wanted to check before I do anything too stupid!
    Thanks, JR
    brute force means slow. No way around it. Thats why there are irradience map and lightcache
    Sorry I dont think you can improve rendertime from brute, by tweaks, not by a lot anyway.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thanks Morbid,
      As I've been testing, your comments seem true!
      Now it's saying the scene will take about 12 hours!
      Sometimes this may be okay, but others, I guess I'll stick to IR Map...
      Thanks
        Sounds like maxwell!
          brute force is a form of path tracing. So yes it will take very long time.
          Dmitry Vinnik
          ShowReel:
            Yes, like MW, but at least it isn't as noisy, lol
              12 hours seems resonably fast to me for brute force. Ive had scenes of around that resolution that have taken 24 hours + and that was using IR+LC with barely acceptable antialiasing so i guess it is really scene dependant. would be nice to do some comparisons in relative speed difference from a small scene, medium scene, large scene, large scene with lots of glossies etc etc
                what would be the benifits of using brute force or irmap ? can a higher quality be obtained using brute force? i guess it's more exact when use have enough samples and such ?
                My Homepage : http://www.pixelstudio.nl
                  Depends on how you define higher quality. The lighting solution will be more correct than IR or LC, but might be noisier...
                  "Why can't I build a dirigible with my mind?"
