Ground Cover
  • Ground Cover
    Does anybody have any good tips on ground cover? I have a scene the will require an almost forest floor look.
    Any help would be greatly appreciated.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    "Scatter" with some nicely modelled organic stuff. Leaves, twigs, crap, etc., etc.. That, placed over a mesh with "noise modifier" applied to it and vray displace should do the trick.
    joel burbage
    strivestudios
    www.strive3d.com | www.joelburbage.com
      Some thoughts... Been working on something similar lately. The bottleneck will be max's ability to handle large object numbers. If you keep the vegetation / groundcover in a separate file, and xref it, you can work with proxies almost all the way. Just model some typical elements, and scatter based on the surroundings. Oh, and doing the scattering by hand isn't always the best way to go, since you may tend to paint patterns. And don't forget about opacity mapped planes. Works quite well too for smaller details.
      A.
      credit for avatar goes here
        would most likely go with xref too ... probably only populate the foreground with 3d models
        and those in the midground and background will only have texture map and some nice
        normals bump... those objects are quite small will not require so much attention if the
        resolution wont show...
        Studio Max 2009 x64
        X5000 Chipset | Dual Core Intel 5140 | 4G RAM | Nvidia FX3450 drv 6.14.10.9185
          I believe this thread may help a little...
          http://www.chaosgroup.com/forums/vbu...ad.php?t=30154
            Groud Cover
            I followed that link, thanks. This guys work is something I like.... any clue of the software?
            http://www.vpii.com/residential.html
            I saw his work over on vue 6, but I also read that vue doesn't work with vray. Does anybody use vue?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Can you get Vue models into Max/Vray?
              "Why can't I build a dirigible with my mind?"
                You can export Vue models as 3DS or OBJ and import in MAX, we tried with some of their trees and they don't look any good, much better to use Onixtree or any other specific tree package.
                The strength of Vue in rendering terrains is the procedural texture system, much better than MAX's native, but if you import a terrain in MAX you cant use Vue materials ...
                There is a connection plugin that lets you render Vue scenes in max using MR, no VRay support. We tried to make some renders with this system but, in my opinion, it's way too annoying and buggy to use. Guess someone else had better luck with it, I personally hate the way Vue works.
                  Vue
                  It seems for backgrounds it might be nice.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Proxy Painter is genius:
                    http://www.webalice.it/pietro.salerno0/index.html
                    You can use clone & align to replace scattered dummy objects with vray proxies.
                    Or use Particle Flow:
                    http://www.createforum.com/3dslondon...orum=3dslondon
                    www.meetup.com/3DLondon
                      Proxy Painter
                      pardon my language, but holy crap! Proxy Painter is incredible, or at least the video tutorial is. This tool alone looks like it'll solve a lot of my limitations. How many more of these "can't live without" scripts are hiding out there?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Proxy Paint
                        I am devastated... it doesn't work for me. I am running max 9 (86) and when I pick my button I see a cmd box pop open, but close just as fast.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Proxy Painter
                          I tried another machine and it doesn't work there either. The second machine is MAX 9 on XP64. Cruel joke showing me this script and it doesn't work.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Scatter
                            I did find this, which works, but doesn't seem as nice.
                            http://3dcenter.ru/forum/index.php?showtopic=82821
                            and this, which I haven't tried yet.
                            http://highend3d.com/3dsmax/download...Tool-3749.html
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Works exactly as expected here mate.
                              works really well infact. The 64k poly mesh limit is annoying tho.
