Backburner VS Just Vray DR
  • Backburner VS Just Vray DR
    Hi all
    I'm confused again (or should I say still). I've tried backburner ones before without much success a long time ago. It seems a lot of people are using BB instead of just DR. What are the pros and cons of both?
    I don't know why you would want to use BB if you can use DR (bear in mind I know squat about BB). OK so sometimes when I'm using DR, the renderslaves kick in a bit late, when my workstation already almost rendered half of the image by itself! I experienced this with high res stills as well as 768X576 animation frames. Sometimes my pc renders the whole animation frame before the slaves even think of starting to render. (slaves is same spec as workstation more or less) and (various render times from 5 minutes to 20 minutes a frame). Will BB fix this problem for me?
    What is the best way to render animation? 10 PC's each sharing one frame or each PC doing its own frame? (if BB can do such a thing)
    Kind Regards
    Your LOST newbie
    Morne
    Kind Regards,
    Morne
    Yes. I'd say in your animation example using backburner will be more efficient. As long as you have more frames than farm boxes DR will not be faster.
    Eric Boer
    Dev
      Render more you will find out why BB is there and why DR is also cool... they both serve their purpose.
      Studio Max 2009 x64
      X5000 Chipset | Dual Core Intel 5140 | 4G RAM | Nvidia FX3450 drv 6.14.10.9185
        The reason to use BB is for queue management. If you are rendering an image overnight, and one or two others on your team are doing the same, how do you queue them otherwise? Before 1.5, you had to use BB render strips if you wanted to use all your nodes.
        The reason DR is faster than BB render strips is because render strips always overlap by about 50 % regardless of specified overlap.
        We can now send DR via BB, so there is no reason to use render strips anymore.
        Usually your nodes kick in late because they are still rendering their LC pass. LC is not yet distributed.
        "Why can't I build a dirigible with my mind?"
          @Clifton
          Thanks that makes sense, and I geuss it will make more sense if I actually try it with the next animation job I get. Is sending DR to BB usefull for 1 still also or mainly for animation?
          Kind Regards,
          Morne
            Sending an animation to backburner DR does not make sense...
            Eric Boer
            Dev
              Like RErender said. DR is faster for stills, but for animations its not important. Animations are naturally distributed because of the nature of the exercise. The only time it might seem helpful is if you have really slow nodes and at the end of the sequence you are waiting too long for you slow nodes to finish. But if thats the case, you should just retire those tired nodes...
              It seems like a tough decision to make, but I retire a node after 3 years (and donate it to IT for a server or whatever), because the cost/speed ratio just doesn't make sense.
                Ahh but calc'ing an irradiance map with DR before sending to backburner does!
                Dave Buchhofer. // Vsaiwrk
                  True, but I still would prefer sending individual frames to calc per box and merging the imaps, it is more foolproof.
                  Eric Boer
                  Dev
                    huh? I'm now even more confused than before
                    with bb does each machine do its own frame or does all the pc's still share the same frame at the same time?
                    Kind Regards,
                    Morne
                      In BB, each machine will do a frame, unless you specify otherwise. If you use strip rendering or DR via BB, then the nodes share a frame, which is good for still renderings.
                        so to clarify, in animations it is best to have each pc do its own frame, and for stills all pc's share the same frame?
                        AND in animation it is better to use BB than DR?
                        what is the difference between using DR with BB and just using BB or is it the same thing?
                        Kind Regards,
                        Morne
                          Okay. You can do DR by itself. You can do BB by itself, either with each node rendering a frame, or all nodes contributing to a frame using render strips. You can now, in 1.5 sp1, do DR with BB.
                          Unless you have only one computer, you want to use BB or DR so that all your nodes can contribute to your job. DR is faster than BB render strips for still renderings. If you have more than one person in your office doing DR, it is helpful to queue your DR jobs in BB, so there is no conflict.
                          For animations, you don't need to use DR. Just BB.
                          You should probably practice using both DR and BB and these things will become very obvious.
                            thanks I usually use dr for stills and animations. Never tried bb.
                            So once I've tried bb, what is best to do animations, strip rendering with bb or each pc doing a whole frame by itself with bb?
                            Kind Regards,
                            Morne
                            • #15
                              How do you queue a job without BB? Do you use a different render manager?
                              Render strips are for stills. It allows each computer to contribute to a frame. It has about 40% overlap, so it will always be slower than DR. There is no need to use render strips any more, so don't worry about it.
                              For animations, just send to BB. Do not use render strips or DR.
