Work Flow Improvements
- Scene/Composition Export from MAX to AE
- Scene/Composition Import from AE to MAX
- Fast Clipboard Export option
- UVW Coordinate support for AE Helpers
User Interface Changes
- Corner Creation method for AE Helper Layers
- Helpers are two sided and include orientation arrow
Other Enhancements
- 3ds max 9/2008 (w32 and x64) support
- Key Reduction Improvements
- Improved rotation/orientation accuracy
MAX2AE is a full featured plugin for 3ds MAX 6 and higher that bridges the gap between MAX and After Effects. Finally an easy, accurate and highly efficient way to integrate After Effects elements into your MAX renders, matching all aspects and parameters of Max cameras, lights and objects.
Every property of a MAX camera, object and light can be translated into AE. Far more than just camera matching; MAX2AE offers object to layer animation matching, MAX light to AE light animation matching and handles all resolutions, pixel aspects and frame rates.
MAX2AE incorporates the ability to create 'helper planes' in MAX which represent your AE layer or comp. These 'helpers' provide a highly accurate way to envision the AE layer relevant to your MAX scene. These 'helpers' can be animated just like any other MAX object, then used to output keyframe data to AE layers for a perfect match! Even allowing them to be rendered from MAX for the purpose of generating track mattes for object/AE layer occlusion!
Explore for yourself the benefits of having a seemlessly matched animated Cameras, Objects and Lights with MAX2AE!
