[coding] External Symbols
  • [coding] External Symbols
    Hi there people,
    i was experimenting a bit with the sdk.
    i have the following code:
    std::string MsgStr;
    PixelBufferInterface *pixelBuffer=static_cast<PixelBufferInterface*>(GE T_INTERFACE(vrayVFB, EXT_PIXEL_BUFFER_INTERFACE));
    if (pixelBuffer) {
    int width=pixelBuffer->getWidth();
    int height=pixelBuffer->getHeight();
    //printf("Image size is %i x %i\n", width, height);
    MsgStr += "Image width is :";
    MsgStr += width;
    //CString cs(MsgStr.c_str());
    MessageBox(NULL,MsgStr.c_str(),"Warning",MB_OK);
    it all compiles fine, but when i try to build the project i get an error:
    error LNK2019: unresolved external symbol "class ClassDesc2 * __cdecl GetInterfaceToolDesc(void)" (?GetInterfaceToolDesc@@YAPAVClassDesc2@@XZ) referenced in function "class ClassDesc * __cdecl LibClassDesc(int)" (?LibClassDesc@@YAPAVClassDesc@@H@Z)
    the only thing i change in this code (what was taken from the help file) was :EXT_PIXEL_BUFFER_INTERFACE
    the helpfile it says without EXT_ and that i not working.
    Perhaps you c++ guru's know why i get this error ?
    i added a couple of lib files to my project but that does not seem to solve it.
    ps: there is a little typo error in the help by getting the width
    My Homepage : http://www.pixelstudio.nl
    Just copy and paste the InterfaceID for EXT_PIXEL_BUFFER_INTERFACE and it should be fine. For some weird reason it is not a #define like other extensions.
      hmm was something else,
      i put a part of code in the vutils namespace, corrected this and it seems to work. even with EXT_PIXEL_BUFFER_INTERFACE
        Ah, good.
          i'm still trying to connect to the VFB,
          i use the following function:
          std::string MsgStr;
          //#define EXT_PIXEL_BUFFER_INTERFACE InterfaceID(LARGE_CONST(2005120901))
          //EXT EXT_PIXEL_BUFFER_INTERFACE
          VUtils::PixelBufferInterface *pixelBuffer=static_cast<VUtils::PixelBufferInterf ace*>(GET_INTERFACE(vrayVFB,EXT_PIXEL_BUFFER_INTER FACE));
          if (pixelBuffer) {
          MsgStr += width;
          } else {
          MessageBox(NULL,"Connect to VFB Failed...","Warning", MB_OK);
          for some reason pixelBuffer is null and i get connect to vfb failed.
          i tried using the const value instead of : EXT_PIXEL_BUFFER_INTERFACE but that also does not work. the declaration for the vrayVFB is : VUtils::VRayVFB *vrayVFB;
          any idea what i'm doing wrong ?
          cheers
            Where do you obtain the vrayVFB variable value from?
              hmm that is a good question
              i have to check if the vrayVFB is filled with something in this function.
              hmm thx. something to look into. i'll repost when i have something new.
                Hmm before get_interface need a vrayVFB.
                i declare vrayVFB as : VUtils::VRayVFB *vrayVFB
                For getting contense of the vrayvfb do i need to create a new one?
                if yes, then i should use:
                VRayExport VRayVFB * VUtils::VRayVFB::newDefaultVRayVFB (VRayVFBNotifyCallback *notifyCb, int noGUI)
                Perhaps you have can show an example how to do this cause i'm not gettings this to work.....
                  You can obtain a pointer to the current frame buffer if you use the V-Ray renderer interface (e.g. you get a pointer to the current renderer, obtain from it a VRENDER_INTERFACE interface, cast it to a VRenderInterface class and call its method for accessing the current VFB). I don't have the code in front of me right now, but I'll check later and post it.
                    hmm i tried something but still doing things wrong hehehe c++ is hard to get used to. but well i'll keepon trying. this is what i have sofar:
                    VRenderInterface *vrender=GetVRenderInterface(GetCOREInterface()->GetCurrentRenderer());
                    if (vrender) {
                    // Renderer is V-Ray
                    //now get a pointer to the vrayrender.. ?
                    MessageBox(NULL,"Render is vray","Warning", MB_OK);
                    //VR::VRayVFB * getRenderVFB(vrayVFB);
                    VUtils::VRayVFB *vrayVFB=static_cast<VR::VRayVFB*>(getRenderVFB);
                    VUtils::PixelBufferInterface *pixelBuffer=static_cast<VUtils::PixelBufferInterf ace*>(GET_INTERFACE(vrayVFB,LARGE_CONST(2005120901 )));
                    if (pixelBuffer) {
                    MsgStr += width;
                    } else {
                    btw: tested with the large_const number instead of ext_.... to see if it made a difference.
                      Eh, you are supposed to call the method, not to get its address It should be like this:
                      Code:
                      VUtils::VRayVFB *vrayVFB=vrender->getRenderVFB();
                      if (vrayVFB) {
                        // Do something...
