Just wondered if it is possible to reduce the intensity/brightness of the sun without affecting the intensity/brightness of the vraysky? I still want the connection between the colouration/time of day of the vraysky by moving the vraysun, but I don't necessarily want the maximum intensity of the sun on all occasions.
Reducing intensity of vraysun
Kind Regards,
Richard Birket
http://www.blinkimage.com
----------------------------------->Tags: None
But if I split them up, doesn't that mean I loose the time-of-day connection?Kind Regards,
Richard Birket
But I thought that the position (ie time) of the vraysun dictated the colouration as well as the intensity of the vraysky?Kind Regards,
Richard Birket
VraySun is related to VraySky...
Bring down the intensity of the sun and sky will follow
Create 2 suns. The first one wil prompt you for Vray sky, say yes, place it, turn it off, then create a second one, say no to the prompt question. so your sky is controlled by the first sun placement. Lower your first (off) sun, and you'll get a dusk sky with a noon sun, if you wan toAlain Blanchette
www.pixistudio.com
Originally posted by thablanch View PostBring down the intensity of the sun and sky will follow
Tricky - the position of the sun does control the colour of the sky, yeah. Lowering the intensity of the sun wont change that.Last edited by Neilg; 19-06-2008, 03:15 AM.
Well 'theblanch', I dont know how youve got it set up, but when I do that exact thing on mine the environment light levels stay exactly the same.
Turn sun off, render with intensity on 1. Change intensity to .01 and the render looks exactly the same.
Did you try checking the manual sun node checkbox like I said in my original post?Last edited by Neilg; 19-06-2008, 04:11 AM.
