IES Renderings?
  • IES Renderings?
    Hi all,
    Is there any method of viewing large quantities of IES light renders quickly? Is there anything that can quickly generate an image like I have attached here? This would be hugely helpful when trying to decide which IES file to use for a particular application.
    I have IES Viewer v2.99n. It offers what I want, but is much too slow when trying to view hundreds of IES files to find the right one to use.
    Thanks for any help you can offer.
    - Tim in Hollywood
    It could be scripted. How much is it worth to you?
    Eric Boer
    Dev
      Hi, I use the same exact program you mentioned and I am quite pleased with the speed. I usually have it set to thumbnail with the render window open, and go through dozens (30-70) of files quickly...HTH
        voltron7,
        You are quite correct. Using the program I mentioned, I discovered how to rapidly go through hundreds of IES files. I can probably go through 75/minute, so I'm quite pleased.
        Thanks,
        Tim
