Irradiance quick question
  • Irradiance quick question
    Is this line normal? There is no problem at all in render, but saw that there is a lines in IR when i render in network, thats its absent when render with single machine....
    Andrian
    _____________________________________
    www.fekta.eu
    Portfolio
    CG Talk
    you dont have DR turned on do you?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      upper half is DR turn ON
      other half is off....
      Andrian
      www.fekta.eu
      Portfolio
      CG Talk
        turn DR off and the lines will go away
        Chris Jackson
        Shiftmedia
          Do the imap lines line up with the edges of the buckets? This looks similar to a "problem" I questioned about the edges of DR buckets ( http://www.chaosgroup.com/forums/vbu...ad.php?t=37719 ). I've continued to notice it during the calc phase but it never really seemed to impact the final images.
            In DR mode, V-Ray switches off the multi-pass option of the irradiance map - this is because each machine calculates its own irradiance map without information from the other machines - the result is accumulated on the client machine and then redistributed to the slaves after all of the irradiance map is calculated. This is the reason why you get the lines...
              thx for the reply's, as I say in the beggining, there is no issue with irradiance after I render the picture, I just ask is that normal...and appear to be normal.
              Andrian
              www.fekta.eu
              Portfolio
              CG Talk
