Is it possible to export an .exr render element image with an embedded alpha from a .vrimg file using vrimg2exr.exe? I want each exported render element image to have its own alpha just like images generated from the V-Ray Frame Buffer/Split Render Channels option with "Save alpha" checked.
Using the "alpha" element to mask out the render channels in CS3 is producing fringing around objects. The only way I've been able to get a clean composite with no fringing is to use the V-Ray Frame Buffer/Split Render Channels/Save Alpha option but due to memory limitations I am not able render large print resolution images this way. I have to render to the .vrimg format instead.....
