mtl select through refr.
  • mtl select through refr.
    Hi all,
    is there a way to get the matlSelect pass work through refractions?
    i have an object with an vrayblendMat with fast sss inside, wich is flying inside a glass object.
    i'am using the MtlSelect for the fast sss, for controling the sss effect later, but when the object is inside the glass..
    thanks and Best regards
    Jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    It will only work with transparency, not refraction, for the time being.
      ok, thanks.
      for the time being means its planned?
      Jonas
      www.jonas-balzer.de
      www.shack.de
        ah, another question on this:
        i would like to do the Dof in post. so here is the same problem. when i render out the ZDepht it wan't work from the moment the object is inside the glass.
        and i've seen a thing wich i'am a bit curios about. when i look through the glass, and i want the flying object in focus, so the glass in front is out of focus, strictly observed is all of the object seen through the glass refraction right? so when the glass in front is out of focus, the refraction of the flying object have to be out of focus too. or?
        but when i render it with dof in VRay, all from the object directly seen through the glass is sharp.
        I'am sure its right like that, but could someone discribe why?
        and does anybody know a way to fake that effect for doing it in post without having zdepht channel works with refraction?
        Thanks in advance, and best regards
        Jonas
        Jonas
        www.jonas-balzer.de
        www.shack.de
