Skyportal and desaturate vraysun/sky
  • Skyportal and desaturate vraysun/sky
    Does vray light skyportal only work with Vray sun/sky? And is there any way to desaturate vray sky/sun?
    vray light portal works with gi. It acts as a gateway to assist tracing gi from the area which is specified by vray light.
    About sun/sky, there is no way to directly correct the color of the sky and the sun. However you can use a plugin called color correct for 3ds max, and run your sky through it, there you can correct the saturation.
    But, the sky is built on a physically accurate formula, what you may want to do first is play around with gamma corrections.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Also look at the color balance option in the physcam
      Eric Boer
      Dev
        I remember it's there to directly render light coming from behind the portal itself, not to aid the GI. (Of course, it will aid it in some way, since gi calculated from the direct light of the portal will probably be less noisy) I'm just curious, so correct me if I'm wrong.
        A.
        credit for avatar goes here
          "portal" will sample the gi in the area of light...its a known approach to improve gi quality in interriors...fryrender for example employs same technique.
          Dmitry Vinnik
          ShowReel:
            I tried skyportal without vray sun/sky today and it didnĀ“t do anything.. we use it a lot with vray sun/sky tho and then it works perfectly.
              "And is there any way to desaturate vray sky/sun?"
              Stick the sky in a color correction node and put that back in the environment box. You can juice or dejuice it to your hearts content.
