VRayFur styler
  • #16
    Nice Always the swift response.
    Signing out,
    Christian
    • #17
      hi Vlado
      thank you very, very much...!
      cheers phil
      http://www.ped-cg.de
      • #18
        Hello,
        I am testing it Vray Fur Styler for the first time. I am using max2009 with Vray 1.5 SP4a.
        When I try to paint, I don't see the results in the viewport.
        Is this normal or is something wrong?
        1. I put UVW map on source object. (I both tried box-mapping and planar mapping)
        2. U put Vraystyler on source object.
        3. On vrayfur object, I put vertex color map on Bend slot. I copy this map to Material Editor and make the map channel 2.
        4. 3. On vrayfur object, I put another vertex color map on InitalDirection slot. I copy this map to Material Editor and make the map channel 3.
        5. I select source object, click on paint and try to move the direction of fur in the viewport. But nothing moves or happen.
        What am I doing wrong?
        for my blog and tutorials:
        www.alfasmyrna.com
        • #19
          You would need to instance the maps to the Material Editor, rather than copying them, before setting the map channels.
          • #20
            Actually I instanced the maps and I intended to mean this. Sorry about the mistake.
            So what could possibly be the reason that I can't make it work?
            www.alfasmyrna.com
            • #21
              Any idea?
              Is there a compatiblity problem with SP4a?
              How can I make this work?
              www.alfasmyrna.com
              • #22
                The VRayFurStyler does not depend on V-Ray itself in any way.
                My simple tests worked, but perhaps you are doing something different... if you like, I can attach a working scene here.
                • #23
                  Yes please and thank you
                  I am using max2009-64 bit.
                  With that scene, I can test if I can brush.
                  In all my experiments, everything seems to look fine until using the brush. When I start brushing, it has no effect on furs.
                  Thanks a lot.
                  www.alfasmyrna.com
                  • #24
                    Hi again Vlado,
                    Can you upload the file for me so I can test?
                    Thank you very much.
                    www.alfasmyrna.com
                    • #25
                      Here is a simple scene (for 3ds Max 2010).
                      • #26
                        Thanks. Is it possible to make it for max2009 ?
                        I am on max2009.
                        www.alfasmyrna.com
