You sometimes get that kind of thing if the object is inside out, try adding a Normal modifier. Second, use the sweep modifier! It kind of replaced the Loft compound object and it's much more flexible.
sometimes I get this with sweep, too. Helps to make sure the path spline has enough interp. subs, and turning off smooth path and smooth section. I usually get them looking nice by adjusting those settings...best luck.
