VRayObjectID and VRayMtl Opacity
  • VRayObjectID and VRayMtl Opacity
    Hello,
    I am rendering a material using opacity and would like to be able to save the render element for tweaking in photoshop. The object is the water fountain and the MaterialID grabs the entire plane. How can I save a Render Element with the opacity in the material to select it easily later in post.
    Thanks
    Is the water dropping down a texture mapped onto a plane ?
    If that is the case then the materialID is doing its job correctly. It cannot distinguish each drop of water on the texture map and create a seperate id for it. You would either need to turn the water droplets into geometry (particle system), or better still would be to just render out the plane on its own with opacity and save as a png or some other format that has the ability to produce an alpha channel with it
    Regards
    Steve
    My Portfolio
      Yep, just a material on a plane.
        Check out my post above...i edited it just after I sent it
        Regards
        Steve
        My Portfolio
          I was afraid so , thanks for the reply.
            If you just render the water droplets with an alpha channel you can bring that layer into photoshop and be able to tweak easily.
            Regards
            Steve
            My Portfolio
