DR questions
  • DR questions
    Hi
    I am about to add 2 Pcs to my current Net.
    If I add a PC which is slower or faster - Does Vray manage the work between the nodes so that most or all of them finish rendering the whole image at the same time (rendering 1 frame)?
    Also - Does MAX/Vray need a video card on these nodes (I will only use them as such)
    Regards
    (my system is max 2009 /vray/XP64 Pro
    Nir
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    No on both of your questions, DR will split the image up depending on the size of the buckets you choose however it doesn't care how fast the DR machines are and if they are to slow you may not see any benefit in using them.
      Devin
      Thanks
